Hi there
Earlyear today I rebooted my W1 to XP Pro and is up and running but the probleam im having is that i cannot install my pre-installed software e.g Giga Pocket, DV Gate and so on.
After I installed XP Pro to my W1 I then insert its orinigal boot disk to install the sony software, but when i click on ''Install All App's'' it says ''VRU.exe Missing''.
I was wondering if someone had any ideas about how I can install my orinigal software.
Any Ideas will be most useful.
From Dean
If you put in the applications DVD into the VAIO when at the desktop it should work
I think you need to install the pre-installed Sony utilities (download from Vaio Link) before you can re-install the applications.
I'm having this problem! I've just done a clean install of XP Pro and can't get any of my apps off my recovery cd, despite re-installing all the Utilities and Drivers.
That said, Rich pointed me in the direction of this: http://myplc.com/sony/sony_apps.htm
Don't know if it'll work yet, but it's worth a try!
You see that's the thing isn't it?! I mean, you go out and spend £1500.00 on a desktop and you're forced into using an OS you don't want!
I wanted XP Pro on mine when I got it, but settled for Home becuase it was new and I couldn't be bothered with faffing about installing Pro. Now I've done it, it's such a flamin' hastle! Sony really shouldn't restrict their customers to OS' they don't want. Trouble is, you want the Vaio-Zone software and SonicStage or whatever and can't get the apps (which you've PAID for!) off the damn disc! As Nan would say, "What a f**kin' liberty!!!" Lol!:smileylaugh:
C'mon Sony, does it matter what OS people install? We've paid you, who've paid your developers, so we should be intitled to use the programs on whatever platform we like!
...So there!
