My Vaio aw11mh has suddenly stopped playing blu-ray discs and is displaying a msg box saying that it doesn't recognise the discs. anyone know what could be the problem?
Thanks
Hi thegannet,
welcome to Club VAIO..
Have you installed the winDVD BD updates available for your VAIO..
WinDVD BD Update - 8.0.9.670_2
WinDVD BD Update - 8.0.9.754
If not you can download the updates from Vaio support..
To open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGN AW.
Then next to Select Model - select AW11MH
Then click Log-In
Once logged select Downloads and follow the installation instructions..
Thanks for the swift reply Thalamus, will give it a go and let u know how i got on.
Cheers
Hi! I did and it works now!
Thanks a million!
V.
Hi thegannet,
welcome to Club VAIO..![]()
Have you installed the winDVD BD updates available for your VAIO..![]()
Then click Log-In
Cheers
Thanks a million!
V.
