Battery Not Recognised in Laptop
mrsgilbey
Visitor
Hi - I have a Sony Vaio purchased in 2006. Up until now I have never needed to use the laptop without my power supply. I have now discovered that I can't as my laptop is telling me that I don't have a battery!!! I have checked it is plugged in properly etc and it is, do I need to change any settings? I googled the issue and it seems lots of other people have the same issue. I just can't find any solutions?
Please help, I don't really want to have to spend money on a new battery.
Thanks
D
1 REPLY 1
Thalamus.
Champion
Hi mrsgilbey,
welcome to Club VAIO.. :slight_smile:
Is would appear that you need to purchase a replacement battery.. :slight_frown:
A simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if you can try another similar battery in your Vaio..
