Why does my new Bravia keep switching itself off?
profile.country.en_GB.title
hamster60
I have had a new Bravia for all of five weeks.  Its been working perfectly.  I love it.  Then tonight it just switched itsself off. I turned it on and it lasted thirty seconds before flicking itself off and then back on and then off.....
Its connected to a Sky Box but its not making any difference whether I switch it on with the remote or manually.  It just turns itself off again.
Anyone experienced this?
Thank you.
Bravia55HX
Hi,
very odd, but since you have only had this for a few weeks i would suggest that you take this up with your dealer who should arrange for a replacement as clearly its not right.
38 RISPOSTE 38
profile.country.nl_NL.title
tcviper
If you go to SETTINGS > SYSTEM, see if you enabled power saving/idle tv standby options. If you don't want this turn them both OFF.
Bravia55HX
Hi,
this is nothing to do with the eco settings although if you can get the set to stay on long enough you should disable them, however since the set was fine before its more likely that there is a fault with the power management and will require a Sony service technician to take a look.
hamster60
That's the thing. I switched it off for 24 hours. Turned it on played a show on Sky Plus and watched it, I thought that was it. The minute I switched over, it started doing it. The button on the front going from red to green, sometimes homing back on and getting my hopes up for all of thirty seconds!
Bravia55HX
Hi,
soulman-ian
same sort of problem ,but it does warn us saying tv has been idle for too long and will shut down ,strange as were are watching a film .
bravia2
why does my bravia switch itself off
Anonymous
Non applicabile
Hi there
Unfortunately more information is required from you in order to give an answer better than:
  1. You turned it off yourself
  2. You have a sleep timer set
  3. Idle TV standby is set to a value
So a model number of your tv may help.  As well as any other relevent details
Cheers
oldsmoker1
My TV turns off for no good reason, I can turn it back on, and it may stay on for a few hours or a few minutes and this is very annoying.  Any ideas?
Anonymous
Non applicabile
Hi oldsmoker1
As i said in my post above, a model number of the tv helps.  This is because settings differ from one model to the next.
Cheers
