SWF BR100 compatibility
tommytugboat
Explorer
Does the wireless Subwoofer SWF BR100 connect to any othe brand of TV. More specifically an LG 47LM670T-ZA.
Tags (3)
6 REPLIES 6
Anonymous
Not applicable
Hi
Unfortunatley the SWF-BR100 will only work on the selected Sony TVs.  This subwoofer has a wireless usb transceiver which other branded TVs would not have the required software drivers installed.
Cheers
tommytugboat
Explorer
Ok thanks for reply. One reply provided more information than 35 mins on the phone to Sony support
Anonymous
Not applicable
Your welcome :slight_smile:
Pockets24
Explorer
Hi.
I have two Sony Bravia TV’s, are these both compatible with the Sony SWF-BR100
KD-55X8509C and KD-55AG9.
I wish Sony could make it easier to know which models are compatible.
It says KD models are and my KD-558509C works perfectly but I can’t get it to work with the KD-55AG9.
Any advise would be great.
Thank you.
LightFoot
Specialist
@Pockets24 wrote:
Hi.
Thank you.
Hi @Pockets24
There shouldn’t be any need to keep repeating the same post, especially on posts that are over 6 years old! If anybody can help you they will reply to your original post.
Just in case you are not aware this is a customer help’s customer community. You are not asking Sony, for that you should contact Sony Support. For example click on Contact Support at the bottom of this page.
https://www.sony.co.uk/electronics/support/accessories-television-projector-accessories/swf-br100
Pockets24
Explorer
I keep asking because no one is giving me an answer.
You call this a Community well it’s more bullying than any help.
Thank for the link and hopefully someone professional will be able to answer my question.
I also asked the question again because there are ZERO replies on my question.
