SONY BRAVIA KDL-40EX723 Full HD 40" LED 3D TV
SOLVED
profile.country.en_GB.title
homer2012
Visitor
dos this t.v need usb for internet for wi fi or is it built in??. if so why cant i connet 2 wifi virgin media.?? keeps saying plug in usb port.
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi homer2012,
welcome to Questions & Answers..:smileyhappy:
You either need to purchase the Sony UWA-BR100 wifi dongle..
or
if your Virgin wireless router is close to your bravia then you could connect using an ethernet cable..
or
Use a set of homeplugs, something like the TP-Link HomePlug AV Ethernet Adapter Starter Kit, allows you to share data between your router & the device which is connected to the other homeplug via your home's existing AC power sockets..
2 REPLIES 2
Blencogo
Hi homer2012 and welcome.
The specifications for the EX723 say that the optional dongle is required for wireless LAN connection.
http://www.sony.co.uk/support/en/product/KDL-40EX723/specifications
:wink:
Thalamus.
Champion
Hi homer2012,
or
or
