- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KDL-32W653 signal to soundbar
Connecting a 32W653 to a Goodmans soundbar using 'Optical' works but I prefer volume control from the TV. Using analogue through 'Headphones' works but I have concerns about equalisation. 'Audio Out' shares the same jack socket as 'Headphones' and is variable.
Can anyone say whether 'Audio Out' would be a better flat, non-equalised signal?
Are the signal levels compatible?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi viewer543,
I'm not too sure about this and could pass it on to the relevant team, but it might be quicker for you to have a chat with Sony Support about the signal levels on 0207 365 281 (or via the contact form).
Best wishes,
Pascale_F
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for the advice. We shall see what we can find out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks again for the suggestion and when I contacted Sony Support I quickly received this reply:
In response to your enquiry, we can confirm that the communication between the TV and the soundbar through
the optical cable is digital, while the communication between the TV and the headphones through the
AUX cable is Analogue.
Furthermore, we recommend yourself to use the Digital connection to enjoy the best performance and
high quality transfer for the audio from your TV to the soundbar. Also, kindly note that both methods of
connection do not affect audio equalisation.
SONY SUPPORT TEAM
So, no equalisation which is good. I have since compared the signal levels when selecting HEADPHONES and AUDIO OUT and the latter is slightly lower in level but the soundbar can easily compensate.
We are now happily using (analogue) AUDIO OUT into the soundbar with volume control through the TV.
(I would still prefer Digital but moreso want controls centralised.)
I hope this helps someone and the Goodmans Aspect Duo GDSBT 50SS soundar splits it two and stands tidily either side of the screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks a lot for the info. My parents have a generic sound-bar connected with optical and I couldn't make the TV control the Sound-bar's volume! with your help I now connected it through the headphones(out, Bravia TV) to the line in of the sound-bar and it works great!
