Solved! Go to Solution.
Come on Sony please. This is a worse performance than England!
Yep problem is still there - any update yet?
Hi all,
I am told the firmware has been released. So please check if you can update the TV and if Iplayer is working or not.
edit: apparently the update would be pushed automatically to your tv even if in Standby but to be 100% sure better do a manual push in my opinion 😉
Thanks,
Nico
Hi Nico,
Just checked my TV and I have the firmware PKG4.117EUL-0108, which is the same as on the Sony site. Is this still the old firmware as iPlayer is still not connecting?
Linda Adams
Let's give it a couple of hours/1 day for it all to settle before panicking.
I gave you guys the update as soon as I got an email internally so not all servers might have been updated yet.
So let's keep on monitoring this 😉 thanks for the quick check though.
Cheers,
Nico
I think these are the new firmware numbers:
PKG5.054 is the new FW package for the models NX81x and NX71x.
PKG4.118 is for all other models.
Hope this helps.
Cheers,
Nico
As of 12:30 my BBC iplayer is now back working again. Thanks to all concerned but why did it take so long. The addition of ITV Catchup would be good recommence
