apps on Bravia TV
SOLVED
peterg136
Explorer
apps on Bravia TV
I have a KDL-32W705B and the apps are awful, when they even work, basically YouTube and iPlayer (the worst) the rest is bloatware. Now I am bring pushed the "latest" Bravia TVs but there is nothing about the apps on these "smart" sets and are they updated? I like the quality of the TV as a TV, but I don't want another app turkey - I have a small Samsung that leaves the Sony standing in the app stakes.
1 ACCEPTED SOLUTION
Accepted Solutions
peterg136
Explorer
Appreciate the quick reply, and take your point, I guess I'll just run it into the ground and ask more question next time. Cheers
5 REPLIES 5
profile.country.DE.title
Peter_S.
Hi,
Most of the current TVs are Android TVs which means that you can get apps from the Google Play Store and install them as you like - like on a smartphone.
So a big difference to your W705B...
Cheers
Peter
peterg136
Explorer
UVA44-.
Member
Do you mean that one has to buy a new TV? YouTube has always worked but now no more. Can you tell me why, please? Thank you
peterg136
Explorer
Why? Because Sony is another money grabbing corporation, who bim customers once you buy their wares, which are out of date when it hits the store. You wpuld thing they could sell a bow you could connect to the TV, but why do that when you could buy another TV. Go to a better supplier, I know I will. Good quality picture and sound but ***** customer service.
Bat_Rick
New
Applications do require updates to run smoothly, in the case of the non-android TVs, apps are only updated through a complete software update (for the TV) unlike the Android TV, in which you can update the app through Google play store.
Maybe this is why the apps are not functioning, am i making any sense?
