Alexa control for KD-32W800
SOLVED
BagpussBoy
Explorer
Hi,
I’m trying to setup the Alexa control for my KD-32W800, it shows up as a discoverable device to the Alexa, but it doesn’t control the TV. But I can’t find the app to install/configure on the TV itself.
Can anyone tell me if it’s possible, and if so, how.
Thanks
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
LightFoot
Specialist
Hi @BagpussBoy   Have you followed the instructional video?
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-32w800/article...
If the TV Control Setup with Amazon Alexa App is not available on your TV then it is not available.
4 REPLIES 4
LightFoot
Specialist
HannahEd01
Hey BagpussBoy, let us know how it went.
BagpussBoy
Explorer
Thanks for the guidance, unfortunately, although this is a newer TV, it doesn’t have the Alexa control. Sad times.
HannahEd01
Hey BagpussBoy, here's the supported models: https://www.sony.co.uk/electronics/support/articles/00186907
In case you wanted to upgrade.
