Xperia T shuts down by itself frequently
SOLVED
oscarfh
Visitor
Xperia T, bought 2 months ago. It shuts down by itself several times a day and in the night when it´s not being used. It doesn´t reboot, it shuts down. To revive it it´s necessary to reboot using the power and volume-up buttons. The software is 4.0.4/7.0.A.1.303. The update programs report that it´s updated and that there isn´t updates available. The software was re-installed using PC Companion, but this didn´t solve the problem.
Any known solution?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
it might be a faulty SIM card causing this issue, get a brand new MICRO SIM card
3 REPLIES 3
Uliwooly
oscarfh
Visitor
I replaced the SIM card with a new one and have used the phone with it for about a week. It seems that this solved the original problem. The phone is no longer shutting down itself frequently.
However, it has shut down itself twice while charging. When this happens, the notification LED is white. The phone can be restarted pressing and holding the power key until the phone vibrates. It´s not necessary to enter the PIN number.
Uliwooly
repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
