Xperia Play Update Problem ! Computer freezes, phone switches off
SOLVED
Not applicable
Hi guys,
I have my play at android version 2.3.3 and build at 3.0.1.A.0.145 . When I plug phone to PC companion it shows there is an update to 4.0.2.A.0.42
When ever I give phone for update through pc companion the green light indicator glows in phone and my computer freezes and nothing happens. I had to restart both. Please help.
Looking forward for solution.
Thanks
Abhishek
1 ACCEPTED SOLUTION
Accepted Solutions
turn off your firewall and/or antivirus if that doesn't work restart your computer on safe mode (restart and press F8)
and then run Update Service
11 REPLIES 11
Not applicable
I tried connecting my phone in Safemode but it was not detected. I tried even with safemode with networking. Still no use. Slightly_frowning_Face
Not applicable
Still the same issue. Iit asks for to hold the back key before connecting and continue to keep it. When it goes to updating mode my computer freezes and phone stays still with green light on.
gwhispererz
Champion
Hi, try updating with another PC/Laptop.
Not applicable
I will try and let you know soon.
Not applicable
In PC Companion, it will get stuck at "prepare-connecting to phone" stage. It wont go to update stage only.
Not applicable
i don't know is it same problem with you, i also having this problem when i update my PLAY from 2.3.3 to 2.3.4. but, this solved when i update my phone using Window XP (keep failed many times when i using window 7). i think is the bug of driver on window 7 ? or just my PC.. try it in window XP, may be can help u ...
slimshaddy
Hero
