I recently bought this mobile (Android 4.0 Upgradeable) and from the beginning I have experienced problems with the camera. The thing is flash seems to work perfectly while focusing. However, just in the moment that it gets the image focused, the flash immediately turns off. So all pictures taken in low light are just black.
I have upgraded to the latest version of Android as suggested by PC Companion software, but this problems remains the same.
What can I do?
Does anyone have the same problem?
Thanks in advance!
Solved! Go to Solution.
you should take it to a Sony repair center
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
which settings are you using? remember that phones and cameras will struggle to take pictures in low light
With any settigns, the same results. I have tried with autoflash, flass on, scn auto and normal settings...but the problem is the flash turns off just in the momet to take the picture, so it is like taking a picture with no flash at all. Black pictures is what I got
try this
1) settings > apps > all > camera > clear everything
or
2) repair your phone with either SUS or PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I had already tried the 2nd option with no results
In the first option, "clear everything" is the button "clear data"? It is the only one which I can press there
yeah, clear data
No luck with that either...
I guess so... thank u very much anyway for your tips
