xperia lt30at speaker trouble
SOLVED
sneakyDragon
Visitor
I'm having some issues with the speakers. My phone is doing the alerts and ringtones, but any other sounds won't play. I tried to listen to music and nothing plays. I can't hear phone calls. I got the diagnostic app and it said the ear speaker and the microphone failed, but everything else passed.
This started after I listened to something with my headphones. I'm not sure if that has anything to do with it.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Force restart the device (power button+volume up until the phone vibrates).You might want to try to unplug the headphones while listening to music.
alexdon
5 REPLIES 5
_alexdon_
Try settings-apps-all-smart connect,clear data.Restart.
alexdon
sneakyDragon
Visitor
Didn't work. And it seems like it is related to the headphones, since the sounds seem to work when I plug them back in.
_alexdon_
alexdon
sneakyDragon
Visitor
Thanks for the help. I had tried unplugging the headphones before, but that didn't work. After the forced restart, it still wasn't working, but it started to work after I plugged and unplugged the headphones again.
_alexdon_
Cool.
alexdon
