Xperia Gallery problem
mikejodhan
I took out a pic of some writing approximately 10 meters away(0% zoom). When i view the pic on the gallery app, I can clearly see the writing when i fully zoom in on the pic.
But when the same pic is viewed on xperia gallery, it does not even zoom in close, and the writing is unclear. Its not even readable
What is the cause?
Markus1
Leader
It's the same in my phone. The app called "Gallery" can zoom in deeper than "Xperia gallery" can.
What do you think about this forum? Let us know by doing this short survey.
8 RISPOSTE 8
Pavan_Hyuga
what do you mean by "gallery app" in the first place. the one came with ur phone or a d'loaded one?
Uliwooly
Indeed both are the same, either if you access it through the camera or the icon on the launcher, they are the same app. can you elaborate on not being able to zoom in
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
mikejodhan
well both came with the phone
Uliwooly
please take a screenshot and show us both galleries
mikejodhan
The first pic is the xperia gallery ( icon with the white frame and video icon behind it )
The second pic is the gellery (purple picture frame)
These are two stock gallery applications that i cannot uninstall
as you can see,pic 2 zooms in more than pic 1
Uliwooly
I meant the gallery Icons
Markus1
Leader
mikejodhan
Thank you for that info
