Hi there,
i don't find the widget folder in the widget menu. In the version 2.x of the firmware i've done it but in the 4.x version i didn't find it.
Please help.
Thank you for the support!
Solved! Go to Solution.
Did you mean the Folder of menu apps?
If yes, then in the homescreen just drag one app's shortcut into another, then a fodler will be created.
you are my savior!!! thank you so much!!! :smileylaugh::smileylaugh::smileylaugh:
you are welcome.
Thanks.
