Video playback
SOLVED
Not applicable
Video playback
My videos are taken in protrait mode but playbacks are in landscape mode. When I try to rotate my phone, the video rotates as well. How do I get my protrait mode videos to play back the same way they are taken?
Please help. Thinking_Face
1 ACCEPTED SOLUTION
Accepted Solutions
slimshaddy
Hero
download mobo player from the android market and play your video file in that app..
it will work the way you want Winking_Face
3 REPLIES 3
slimshaddy
Hero
Not applicable
Thanks! It works great! However, how do i set it as the default player for my videos?
slimshaddy
Hero
just click on any video..and it will ask , how to open it.. whether in the video player or mobo player..
tick " remeber this \ set as default" and click on mobo player Winking_Face
now everytime you will play a video..mobo player will launch it..
but if you dont get the option of choosing the video player or the mobo..uninstall the app and re=install it..
then you should have the option..
just in case : if you want to remove it as the default player..
go to settings > applications > manage applications > downloaded
then select mobo player..scroll down and select clear defaults Slightly_smiling_Face
mark the thread as answered..
