update problem for xperia s
Jenniffa
hi firstly I am sorry I am new at this.... My phone tells me I have a update to do.  When trying to update with pc companion it gets to the point where is says to turn off phone then reconnect usb while holding the volume down key, but it has already turned the phone off during the check phone stage.  When I try to connect the usb and hold the key it does nothing.... Am I doing something wrong or is there a problem with pc companion?? Help!!!
profile.country.PH.title
MarlonUk1
3 RISPOSTE 3
MarlonUk1
Jenniffa
thank you so much Slightly_smiling_Face it worked
MarlonUk1
glad to help Slightly_smiling_Face
