Update 6.2.B.1.96 slowed down my phone
SOLVED
rharikumar
Visitor
After the 6.2.b.1.96 update to my xperia acro s , my phone has considerable slowed down .
Icons in the home screen ..take time to load and the overall experience is less smoother now ..
Does anybody face the same problem ?
I wish i hadnt updated my phone !!!!
1 ACCEPTED SOLUTION
Accepted Solutions
Bearings
Contributor
Did you use PC Companion to update the latest firmware? What I discovered is that PCC updates merely overwrite the previous firmware trying to keep your data as much as possible. This sometimes will slow down the phone.  My suggestion is you try to do a clean installation using Sony Update Service: http://www.sonymobile.com/in/tools/update-service. This will wipe your phone clean and install everything new. Please backup your data before doing so.
9 REPLIES 9
AliShahbazi
Visitor
this is my problem too , and I Don't know what i can do to fix it Slightly_frowning_Face
Kamali
Visitor
I have issue in network connectivity after update to  6.2.B.1.96. I don't know why updating the software is causing issue in connectivity. this is basic feature of any phone and Sony you will have fix it immediately. it is not just 2000rs phone yar we have paid 30000 rs for this phone and if some one call me now most of time they are hearing "you are not reachable". Please test your updates before publishing to people.
Head32
Visitor
I have the same problem, since I have updated my Xperia S less than 100 mb of RAM, icons slow to appear.
This version of JB is also full of bugs, I'm considering reinstalling ICS as I try to sell my phone and buy any samsung.
I'm sick of these failures on the part of Sony.
Bearings
Contributor
rharikumar
Visitor
Thank u so much . This really worked and the experience is as smoother as before ..... I took a back up and did a factory reset on my phone , erasing all data ... Now it's just good as before Slightly_smiling_Face
Petronix
Visitor
Update Service isnt working for me. It always says there is no connection. I even disable all firewalls and still it wouldnt connect. What am i doing wrong? My AcroS doesnt want to update to a new vrsion at all. PCC is shutting down on the step 2 of the update before it even starts to download anything. Please help. Cheers!
boriskovalski
Visitor
If you can't do this with SUS or PCC try this : http://www.flashtool.net/download.php
jnthkumar89
Visitor
Phone outgoing call is very slow
if I press the name and then 10 to 15 seconds is not responding to going call
if its a low phone or any other problem
Pl help me.:smileyhappy:
narakka
Visitor
Speaker also problem.. After updated new fw, my xperia s sound sound soo horrible.. Now im using half if my volume.. Bcos if u used max vol my speaker going crash... Anyone have same prob?
