Unable to boot. Help!
SOLVED
kriss0011
Visitor
Hi guys Slightly_smiling_Face
I tried to get a newer vesrsion of android than the offical update, so i try to flash several ROMs with "clockwork mod" and i failed, but by mistake I flash a "Gapps".zip.
Now I'm freaked out, because the phone can't start. It make it only to the sony logo and...nothing. I cant start recovery mode (power and volume down) I don't know that else to do. Please guys help, please!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
connect your phone to a wall charger > let it charge for an hour or so then try again with Flashtool
http://talk.sonymobile.com/thread/41609
Don't forget to mark the Correct Answers & Helpful Answers
7 REPLIES 7
Uliwooly
did you flashed a Custom ROM or just different Sony's firmwares?
Uliwooly
kriss0011
Visitor
I flashed official Sony's firmware for android 4.0.4 a month a go. Now i failed to flash anything new. I always get a mistake. Only on Gapps (for android 4.1) the installation was successful.
P.S.holding power botton and volum up the blue light flashes for a moment and than the sony logo appears when i stop pushing.
Uliwooly
oh ok, try my above suggestion
kriss0011
Visitor
THANK YOU!!!
I wait, the flashmode worked and flashtool did what can to best...flash the official firmware...and THANK YOU AGAIN!!!
Uliwooly
:smileyhappy:Anytime
Nadeem_Patel
Visitor
hi guyz,
I am also having same problem, i upgraded to ICS and then the phone is keep on rebooting.
My phone is Xperia Arc S.
Can u let me exact procedures to follow please.... I will be very thankful to you.
