Too many pattern attempts
SOLVED
Not applicable
I lost my pattern and now it says "Too many pattern attempts". When I to get it through email id it does accept. Please help
1 ACCEPTED SOLUTION
Accepted Solutions
Jake-SonyXperia
Champion
I suggest using the Update Service to remove the pattern lock from the handset. Please be aware that this will remove all data from the handsets memory but will not touch a SIM card or memory stick.
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/updateservice/aspen?cc=gb&lc=...
1 REPLY 1
Jake-SonyXperia
Champion
