Text Alert
SOLVED
BigIan42
Visitor
Text Alert
Can we set xperia j to keep giving text alert every so often until a txt is read?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
no, you will need to find an app on the play store to do so, if it's an MMS it will mark you if the mms has been delivered but not read.
3 REPLIES 3
Uliwooly
BigIan42
Visitor
Thanks for your answer. I checked play store and found quite a few apps and have selected "Easy Reminder" which does all I asked for and more.................Thanks
Uliwooly
Anytime Slightly_smiling_Face
