After the last update ( software n : 2.1.A.0.435) my phone doesn't make contacts sync nor with Google account neither with SE, when I try to make it manually everything looks OK but when I open my accounts on PC there is no Change!!!
Before the last update it was working perfectly, I tried many times and no changes.
Did any one face this problem??
Solved! Go to Solution.
it's quite simple
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email, download the file, go to your gmail and add contacts and select the vcf file you just downloaded, and voila done.
Ok, do this simple 'add new contact' task to make you understand the difference between PHONE and GMAIL contacts. Goto PHONEBOOK, tap the create new contact (top rite corner - head with a plus sign), did you see 'Phone contact' and 'xxxx@gmail.com' (your gmail account). Both are different sets of contacts. Since you are not able to sync-ed your gmail contacts, that means your 'xxxx@gmail.com' contact list is empty. Hope this clarifies everything.
So you mean that i I don't have any Google contacts in my phone there will not be any sync?
Simple answer is YES ....
. Finally you have sorted out. Great!
no problem.
Thank you I don't know why I did not think of this before:smileyshocked:
the problem now when I tap on Send contacts a message appears : The application Phonebook (process com.sonyericsson.android.socialphonebook) has stopped unexpectedly. Please try again
I tried many times and I reboot my phone and the same
maybe the phone can't handle so many contacts at once, I have 224 contacts and it work fine, try to do the same but do it in 2 parts (half the contacts then the other half)
The message appears before I can choose any contact. I deleted my contacts and restore some but I still have the same problem, H think there is something wrong in the software.
Thanks for your help
