Sola Netwok problem after call
savadgan
Hi,
I have some problem with my xperia sola.
Its network totally disappear after any call, then i need to wait fo next 5 min for next call when network come.
How to resolve this.I have recently updated to ICS using SUS.
Johan
Master
I suggest that you check if the same problem can be replicated using another SIM card. If yes you could try to reinstall the phone software using SUS.
2 RISPOSTE 2
Johan
Master
savadgan
The Problem was in SIM, i Replaced with other SIM and it seems to be fine. Thanks
