Signal Drops after every call !!! ICS, build 6.1.A.2.50
SOLVED
sachin_arora
Visitor
Whenever I make/receive a call and after I disconnect the call signal gets drop for 10-12 seconds and I have checked my sim card with other mobiles(Iphone) but could not found any problem. Now I am pretty sure that the problem is with Xperia phone only and I checked number of people having xperia S and they are also facing same issue..
Xperia S : 4.0.4, build number- 6.1.A.2.50
Please suggest the solution because in India every other person is facing this problem with xperia S phones.
Thanks much,
Sachin
1 ACCEPTED SOLUTION
Accepted Solutions
sachin_arora
Visitor
I fixed it myself.. here is the solution:
If your are using GSM network change network mode to GSM only, go to settings->mobile network settings->network mode-> GSM Only.
By default it was CDMA(preferred)/GSM.
It should be GSM only.
Now I dont have any problem with network!!!!!!!!!!!!!
5 REPLIES 5
Uliwooly
is this a micro SIM or did you trimmed your sim card?
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
sachin_arora
Visitor
Earlier I trimmed my sim but I thought this problem is coming due to trimmed sim so to make sure I got new micro SIM reissued but still facing same problem..
yea..let me check this thread..
Uliwooly
it could also be a bug or an app acting up
repair your phone with SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
sachin_arora
Visitor
Tried SUS but No Luck..
thanks
sachin_arora
Visitor
