I have got a xperia sp and my friend got a xperia z. My questions is like on a dlna certified tv i can mirror my screen on the phone to the tv can it be done between the xperia sp and the xperia z also. Also i have a samsung tablet which is also dlna certified can i do the same screen mirroring with it too?
Solved! Go to Solution.
Screen mirroring will not work to another Xperia phone. What you can do is to enable the media server in the phone (Settings -> More) and then access the photos, videos and music from the other phone.
I only have tested screen mirroring when I use HDMI connection, when using DLNA, it only displays media files, but why wont you try it, just make sure the phone and the tv is connected on same wifi server
u are not getting what i want. i no on the tv it is possible. i want is mirroring my xperia sp screen on the xperia z. is that possible
