So, I am searching for the GB version of sony, free carrier, GingerBread and also, Ice Cream Sandwich from Spain, and a European (Generic One)
I have the ´´Indian`` one, wich I think is the worldwide one.
And, also, if there is one for all the world, would be interesting to have, thanks :smileygrin:
Solved! Go to Solution.
if you want the original firmware check the XDA Forum for that specific SI number ftf file
you can use the world generic or nordic firmware.
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
How to manually update 2012 Xperias to android 4.0.4
http://talk.sonymobile.com/thread/41609
Ok, mine is:
| Xperia U | 1263-5053 | 6.1.1.B.1.10 | 10/17/2012 |
But, I would like to know, where I can download it? for flashtools
And also, where or wich is the one, or how I can know, from wich countries are each update and from where download them?
Thanks :smileygrin:
if your SI number is on the list then use either PCC or SUS
now if you debranded your phone or flashed your phone your SI number on your phone doesn't match the current firmware
so now, how I will be able, to get the firmware I want?
and, how I know wich type of it I have?
I used indian GB upgraded to ICS...
Any way to gather with the GB/ICS firmwares of my phone?
at least spanish one and if could be possible, worldwide xD
thanks
