Hi,
I have just got my new Xperia T and am now having issues trying to write blog posts. I will start to write a post and then decide that the sentence I wrote would go bettter else where so I try to copy it by holding down on it but it only opens the magnify and doesnt allow me to copy. Has anyone had this issue if so how did you get around it?
Thanks in advance
TheSk8rJesus
Have you tried double clicking a specific word in the sentence that you want to copy and using the slide bars at each side to select the entire sentence.
Please mark as Correct or Helpful Answer. Thanks
Thats brilliant I can now keep blogging thanks
No problem. My pleasure to help you
