hi guys my xperia play has a problem. i installed a rom and my phone rebooted but got stuck in the se logo. i tried lots of things to fix it but nothing has worked.tried pc companion, update service,flashtool and other stuff but it doesnt work. i need help!!!
Solved! Go to Solution.
There are 2 stes to downgrade
1) Official - handing in the smartphone at a service centre you can request to have it re-installed with Android 2.3
2) Unofficial- Flash Gingerbread using Flashtool, your warranty would get void.
Here is how
Downgrade to gingerbread
Remember flashing may void your warranty and you are doing it at your own risk
This is how to downgrade
1)- needed flashtool version 0.6.9.1,,, download here- Flashtool and install it
Run flashtool.exe> Go to C:/ Drive > flashtool > firmwares > delete everything present and exit
2) download rom
3) copy the rom to firmwares folder of flashtool
4) run flashtool> click on the flashing icon ( left side below "file" option),,,Select flashmode > ok
5) left side you must see your firmware name and content ,, on the right side mark boxes as
select ok
6)Wait for it to prepare and it will ask you to connect your mobile, follow the steps carefully and connect flashing will begin and flash
Is your bootloader unlocked ??
Your warranty is void for sure.....
See correct answer here
i think...
but i tried flashtool
did yo try with the link above ?
it contains another version of flashtool with dofferent procedure
same version of flashtool.
i cant use pc companion or update service cause it says the software is modified
and for flashtool and error comes up but ill try again
and i need xperia PLAY SOFTWARE
thanks anyway
and i would like to say can i get it fixed in shops without warranty
Here is how
2) download rom
select ok
I REALLy forgot you have xperia play...
now see the answer below
since you unlock your bootloader its showing software modified
thanx but download taking too longgggggggggg.....
THANK YOU I LOVE YOU YOU ARE THE BEST I WILL DO ANYTHING FOR YOU
