Hi All,
I recently purchased a secondhand xperia x1, which did not come with a manual. However I did read the online manual.
I have successfullly set up my email for my personal email account.
What I want to know about the email is
I have added my outlook address book personal contacts to the phone by active sync.
What I want to know about address books is
3. Can I now add a second / multiple address books (work etc.), if so how.
And lastly, is there away of turning of Active sync as soon as the USB cable is plugged into the PC, cos sometimes I just want to charge and not sync.
If this helps my xperia is on winmo 6.5.
I would appreciate any advice on these matters, and if the info is in the help / manual please just point me there.
Thanks for all your help in advance.
Solved! Go to Solution.
About mail: You can under the account settings for your e-mail select either to move deleted mails to server's recycle bin or to delete them from the server. Press advanced settings under Send/receive options while in the account settings.
About contacts: You can only manage different contact folders if you sync the phone via Exchange. Not while syncing the phone locally with a PC.
i just know how to add another email..
go to settings > eaccounts and sync and then tap on add email..
Thanks for the quick reply slim......
My menu, goes settings>messaging>email>setup email. Then I can add a new account. Is this the same as your method.
Thanks. 1 down 3 issues to go.
i think that shud be it
add ur new account and see if it works or not..
I just found the answer to question 2. Is the email downloaded to the device removed from the server.
Answer no. see
So all I need to know now is how to add a new address book and turning off active sync.
" 2down 2 to go ".
Johan,
Thanks for the reply.
Thats all those issues resolved.
Thanks alot guys for your postings.
Now I have been playing with the X1 for a week, and theres other stuff i need to know, I will check out the other threads and topics for the answers.
