Network Problem on Xperia Arc s
sagar109237
I faced Network Problem on  Xperia Arc s after flashing android 4.0.4 with flash tool. When my phone start my screen make black but when i push lock key it show light phone make open but network error. I cant call anywehere. But network logo show full network. but when i make call it show network error. When i make restart it make right for 2 min but after 2 min it make same as network error. plzzzz help
Uliwooly
just reflash your phone again if that doesn't work then it seems like a hardware issue.
18 RISPOSTE 18
sagar109237
ans plzzzzz
ibz100
Find Sony Update Service, download and install it, then follow through the process to repair your phone. It won't downgrade your phone and is fairly self-explanatory.
Uliwooly
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
sagar109237
it doesnt work same prob here...:(
Uliwooly
most likely its the SIM card, I've seen so many times.
get a new SIM card
also do NOT install any taskillers, task managers, antivirus, ram apps, booster apps, battery apps.
and double check the APN settings
sagar109237
its not work also. plzzzz help
Uliwooly
do you have a data plan? do you have the correct apn settings? did you avoid installing those apps above? is it a BRAND NEW SIM CARD?
sagar109237
yes i hace a credit to call and i avoid athose apps and my sim card id perfect. My sim card work on another mobile perfectly. But i faced prob in my arc s. Plz help
Uliwooly
get a brand new SIM card, just try it, get a brand new SIM card
