as per the above subject my phone xperia play doesn't detect sim network & when i about to select the network error comes " the sim does not allow connection to this network" before this issue i have repaired my phone where in my strip was not working
Solved! Go to Solution.
And you tried with another SIM card as well?
Then you need to send in the phone to a service center for repair. Contact your local Xperia Support for more information:
Have you tried with any other SIM card in your phone? If you have and the problem still persist, try repairing the phone software via PC Companion.
dude sill the same problem persist after rapairing phone software. is there any other way 2 sort it out
