hello i was on my phone and there was 0% so it turned of and i plugged it into the charger ant now it wont turn on again the red LED light was glowing like it should but it stil wont turn on please help
Solved! Go to Solution.
do this
connect your phone to the wall charger > press and hold: power & volume up for 10 seconds > let your phone charge for 1hr > after 1hr try to turn it back on
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
UNRELATED topic, if you have some time please check this thread
do this
OMG ! THANK YOU SO MUCH IT WORKED CANT BELIVE IT !!!!!
