my phone is shown as camera on my computer...for this its not being read by the pc companian
Solved! Go to Solution.
maybe you chose the folder options as picture when you have connected the phone.
go to my computer > do you see Xperia P?
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
it shows as camera icon not the phone icon
that's odd, install SUS > restart your PC > run it > see if it fix the PCC issue
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
