Solved! Go to Solution.
I am not informed into rooting,but I think that if you search for the apk,you will be able to install it.
Are you sure that the application is gone and not moved to another homescreen/application menu?
Check that you haven't disabled the application. Go to settings > apps > all > scroll to the bottom. If you find messaging in the bottom > tap it and enable it.
Impossible,it cannot be removed as it is default.Settings-apps-all-messages.
Of course,that is why.You need to search for it.
