Hi,
I just bourght xperia Ion lt28h, but when i plug the handsfree phone screen goses black and comes a large distorted sound from handsfree and restart,
very annoying cnt play any sound from handsfree,
also tried new software update, factory reset even diffrent handsfrees. but no luck
Is this a hardware issue??
Solved! Go to Solution.
This happens when, battry is full, when battry is low, no problem handsfree works,
repair your phone with either PCC or SUS to narrow down the issue
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
Don't forget to mark the Correct Answers & Helpful Answers
RELATED topic, if you have some time please check this thread
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Repaird several times, but no luck, when the battery is full i cant connect the hands free, phone restart.
but in the evening i can connect and play music for while, but still it goes after while, same with video player and other players as well.
Really sad
