Keyboard or Mouse Connection
SOLVED
Not applicable
Hi,
I have checked in the forums and in google but could not find a clear answer.
I would like to ask if it is possible to connect and use a usb keyboard or mouse to a xperia ray without a docking station (with a micro usb to usb convertor).
If yes does the manufacturer of the keyboard or mouse matter (compatibility issue).
Also is it possible to connect a keyboard through bluetooth.
Thank you in advance for your answers
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
not it's not
Don't forget to mark the Correct Answers & Helpful Answers
4 REPLIES 4
Uliwooly
not it's not
Not applicable
Thank you for your answer.
Uliwooly
anytime
imugur
Visitor
