Hi,
On my Xperia Mini Pro I had some large mp3 files which I deleted to make room for lots of photo's and videos, this worked fine. Once the space was filled, the files were synchronised with Dropbox and I deleted them to create new space however the memory amount is still low at 40MB and telling me that the memory is full?
The MP3's, pictures and videos have been deleted. Is there some kind of cache or recycle bin?
Thanks
Solved! Go to Solution.
the low memory is your internal memory not your SD card
settings > apps > internal storage > move your apps to your SD card, if you've done that then, you need to delete some apps.
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
another alternative is to root your phone and use link2sd and/or partition your SD card
how to partition your SD card
http://talk.sonymobile.com/message/149438#149438
this is how to root
if you have GB use superoneclick
if you have ICS
http://talk.sonymobile.com/thread/38251
Thank you, I should have realised that.
anytime
