illumination bar
Manu1
illumination bar
is der any way to switch off the light coming out of the bar below to save battery when needed???
vinopall
Install the App called "Night Mode"
In its settings, Activate Check mark "Disable Button Backlight"...
It works buddy.. I am using it.
Happy Googling Slightly_smiling_Face
- Vinopall
11 RISPOSTE 11
anandtapas
there is an app called 'XSLights'. you can try
Manu1
not finding it..
anandtapas
this may be non play store app. search for LED  illumination bar control
sfrskz
night mode.
search in store.
Manu1
ok...
Manu1
dat doesn t work fr illumination bar ..
sfrskz
worked for me
Manu1
my phone went off when i pressed start button n had to restart...
Rosie-Posie
there's also an app called screen filter, its main use is to dim the screen, but if you untick 'enable soft-key backlight' it will turn off the illumination bar
I noticed it will come on again if the battery is low - which is really strange, but ok :smileygrin:
