i want to attach my g-mail with android device ?
SOLVED
Not applicable
when i try to instal some apps from the market it gives me msg ( u have to attach ur G-mail with android device ) and iam already from my android device plz help me ?
1 ACCEPTED SOLUTION
Accepted Solutions
yes it does. it must be the same gmail account on your phone
3 REPLIES 3
in order to use the market you must log in w/ your gmail account
also it's easier to find apps through your computer
market.android.com
if you have any other issues, create new threads
make sure you do select the correct answer and helpful answers
Not applicable
i havealready loged in by my g-mail but it still show me this msg ?
and about searching from comp. does it work on wireless network or not ?
