How to take a screenshot?
SOLVED
AliWonder
Visitor
I know I've seen this somewhere on here but cannot find it anywhere - how to take a simple screenshot on an Xperia S?
Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
ArcSBlack
Visitor
Look here!
Press Power+ volume down key until the phone takes the screenshot.
(It takes  3 to 4 seconds of holding time to actually take the image)
Remember!
  • Correct Answers - 30 points
  • Helpful Answers - 10 points
3 REPLIES 3
ArcSBlack
Visitor
Look here!
Remember!
AliWonder
Visitor
Thank you - I knew it was somewhere. This forum is really badly designed; there is no proper 'search' facility before you've posted your question, otherwise I could have found it. I tried searching the main box for 'screenshot' but it found nothing!
ArcSBlack
Visitor
Yup,  you have to be quite calm when using the search option Slightly_smiling_Face
