How do i move the clock display location on my screen?
It moved by itself and I want to move it back
(I have tried resetting the phone)
Solved! Go to Solution.
You mean the one on the desktop? Just press and hold down your finger on the clock for about 1-2 seconds. After this you will feel the phone vibrate and the clock will be marked green. Now you can drag and drop it where you want on the screen.
Oh dear I feel like such a Doofus!
Yes, the same method used for moving the app icons around and deleting them (as you can see I already used?!?!)
it can happen
we often think more complicated than needed
