I updated my xperia p to jelly bean recently and it lags miserably. Especially whatsapp, call logs and text messaging. Please guide me to downgrade it ICS( works smooth ) , or suggest any alternative to run my xperia smoothly on JELLY BEAN.
Solved! Go to Solution.
you have 2 options to downgrade
1) take your phone to a Sony repair center
or
2) use flashtool
Don't forget to mark the Correct Answers & Helpful Answers
Uninstalled all the unecessary default applications and anti-virus. still lags a lot. Does a factory reset using SUS help? Do I need to erase my internal storage too?
if you already deleted all your sms, mms, call logs > repaired your phone with SUS > and the phone still lags then you could use another launcher, phone and messaging apps.
http://talk.sonymobile.com/thread/41609
@uliwooly: Sony service centre cant help in this. Already tried they said they cant downgrade it ICS once updated to JB. I din try repairing by SUS. Do i need to erase my internal storage also?
From sony's webpage: "Our commitment to offering you the best, means that once upgraded you will not be able to revert back to an older version of Android."
I like that..
Repaired via SUS problem persists.
that's odd, not all repair centers offer this, its not that complicated to downgrade, there's always flashtool
@saigopalpuppala don't create new threads on similar topics, you already know about the lag on JB, search the forum for on going threads
