help, i cant get my international keyboard back
SOLVED
natashagreene
Visitor
hay,
im new on the forum and im looking for a bit of advice,
i have a japanese keyboard and cant get my international keyboard back on
i need some help any one please
thanks
:smileyblush:
1 ACCEPTED SOLUTION
Accepted Solutions
natashagreene
Visitor
Its ok chat support hooked me up
Thanks Brett well done if any one gets stuck with this problem just
open a new message> then hold screen for keyboard to appear>hold where text appears>press input method> then select a keyboard great and simple
thanks again
regards
Natasha
8 REPLIES 8
Uliwooly
have you disable any app or the keyboard?
settings > apps > all > scroll to the bottom
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
Uliwooly
also
settings > language & input > you should be able to select Xperia keyboard
natashagreene
Visitor
thanks again
regards
Natasha
Uliwooly
awesome Slightly_smiling_Face
ArcSBlack
Visitor
Looks like he's hunting points, huh? =)))
natashagreene
Visitor
Thanks for ur help uliwooly Smiling_Face_with_Sunglasses
ArcSBlack
Visitor
.. posts, too:)))))
Uliwooly
lol not at all
