hi, i bought a experia j. but i am unable to connect the gps. when i open the navigation, ":waiting for location" dilogue box is displayed. plz help.
I suggest that you try this while being outdoors and check if you're able to get any connection within 10 minutes. I know that it can take sometime the first time you make a GPS connection.
thanks for ur help. my gps config problem is solved. but i had to restore my device
once
