elm theme creator
SOLVED
Not applicable
elm theme creator
hi
i have ThemesCreator-v4.12.2.4 but it has not ELM phone. i could not find a newer version of ThemesCreator.
is there a newer version that have ELM phone? when i load ELM themes with this one it says that this theme has some features that are unknown to this version.
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Dr_Chris
Champion
http://developer.sonyericsson.com/wportal/devworld/downloads/download/dw-65050-themescreator408?cc=g... Sorry, just had a look and there is a new version 4.16, which does include the Elm.Hope this helps
5 REPLIES 5
Dr_Chris
Champion
I'm not aware of a newer version, but can you not use it at all by selecting another phone, even without the features that are unknown to this version?
Dr_Chris
Champion
Dr_Chris
Champion
With regards to the unknown features you mentioned, this may refer to setting the main menu according to theme in your phone, which is only possible by default with the preloaded themes, whereas for other themes you will need to add the.swf file (flash menu file) to the phone's directory, as long as this file is available.
Not applicable
how to customize the main menu... u said something abt a flash _ swf file... can u pls tel me how to include tat in phone...
Dr_Chris
Champion
