Disable Home Button on lock screen
SOLVED
Not applicable
Hi,
Is it possible to disable the home button on the lock screen on an Arc S? When I put the phone in my pocket I think it might turn on the screen several times by accident, draining the battery.
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you can't
Don't forget to mark the Correct Answers & Helpful Answers
2 REPLIES 2
Uliwooly
you can't
paul0165
Visitor
