car holder with charging
SOLVED
fw252
Visitor
hello, All
are there any car holder with charging cradle for acro S?
i use it for navigation and sound source for car stereo at least 2 times every day, so i beware of usb slot cover.
another question is - how to make proper cable for charging?
i have nice 3A usb AC source in car, but phone's battery run down. may be, i need some special usb cable with special signal on ID pin?
with best regards, Sergey
1 ACCEPTED SOLUTION
Accepted Solutions
Rickard
Master
We don't have any own car holder that uses the charging connector on the side but there are 3:rd party holders available like http://brodit.se/productList.html?locale=en&brand=Sony&model=Xperia+Acro+S&pn=prod.
Depending on the battery usage you have your battery may actually slowly discharge even when you have a charger connected but if your battery drains fast i recommend that you try an original charger from us.
1 REPLY 1
Rickard
Master
