Buying xperia SP
SOLVED
INSU_cro
Visitor
Buying xperia SP
So guys I was thinking about buying xperia SP (c5303) and the price in my country is around 200€...
By the specifications i thought it was a great phone for that price but when i saw the topics on this forum it seems quite buggy (flickering problems, unresponsive touch, illumination lights not working, battery draining and overheating and the wifi range or treshold). Should I buy it or no? Or just buy it and leave it on 4.1.2??? Thinking_Face Thinking_Face Thinking_Face
20 REPLIES 20
Nefertaly
Visitor
Please don't buy it. If I could turn, turn back in time.....I wouldn't have bought that thing. NOW I'M stuck and will never be refund.  Believe me don't buy it
blackbox
Contributor
Specs and benchmarks are fine and that, but they're largely irrelevant in the real world. If you can, go try one out in a shop.
If you don't want to root, then consider the small built in storage. If you're a gamer it can be a dealbreaker as you can't move apps to an external SD card anymore (at least without rooting), and you'll soon run low (and slow!).
The screen flicker? Don't have it myself, but @ParaSense has pretty thoroughly looked into it, and it sure sounds like a software issue as it doesn't happen on 4.1.2.
As for KitKat? It's looking unlikely. In 6 months' time the SP will be past its support lifetime.
Overall, it's a well specced phone that performs just OK and for the money not bad. Would I buy another if I lost it? Probably not.
INSU_cro
Visitor
Okay for the memory... I dont care about having lots and lots of apps... I like to keep the phone clean... I think of buying and leaving it on 4.1.2... Slightly_smiling_Face Slightly_smiling_Face Slightly_smiling_Face
blackbox
Contributor
For that money (and if space isn't a concern - still, I'd get the 16Gb one as 8Gb is not a lot), check out the Moto G as well. Not as well specced, but getting great reviews. Cheaper too.
XperiaUser1
Visitor
hi Blackbox
Just out of interest would you care to offer what you WOULD buy if you lost your SP? because the idea that it performs just ok is a joke. it has excellent battery life and offers easily 20% performance over a Moto G for example.
btw The Moto G is a great phone for the price i bought one for my uncle and best friend but the SP is a better phone especially considering you can add storage. the screen is slightly better on the Moto G though.
daverawle
Visitor
I have bought 2 of these and once I flashed them with the 1.201 firmware they are very good 'phones for the price so I'm happy. I haven't suffered the flickering screen issue that many have but that might be because I'm using 'Velis' to control brightness with the system brightness handler disabled, maybe it just masks the problem but it works for me. The Sony brightness handler was dire anyway. I also use Nova Launcher which fixed most of the lag issues that seem to occur with Xperia Home.
If you look around it's possible to pick-up X-SPs at a discount following a lot of discontent with the 4.3 upgrade.
Dave
spuser123
Visitor
I would suggest GO FOR THE SP. It's a really good phone!!!:smileysmileythumbsup:
I play good number of games. Games with good quality graphics and animations. There is no performance lag.The internet is on whole day on my phone, plus I listen to music whenever I like, and play games like anything. And the best part is the battery is awesome! In spite of my heavy duty use.
I hope sincerely that SONY relases Android Kitkat latest version to the SP gang. (we have already signed a petition regarding this!).
With the new software update, believe me, the phone will work blazingly fast!!!
Hope people at SONY are listening! Smiling_Face_with_Halo
SOS3v5
Visitor
Do not under any circumstances buy the Xperia SP, until someone in Sony can be bothered to sort out the terrible software update they have just released which will completely make your phone inoperable. Just read the hundreds of posts and complaints on here since this software update was released....don't do it! Avoid it!
ParaSense1
Contributor
Oh.. so all these blogs,sites and many more forums are all created cause they saw my issue hmmmm.. i feel famous..
check this http://talk.sonymobile.com/t5/Xperia-SP/Maybe-its-time-for-SONY-to-answear-about-screen-flickering/m...
btw i dont have any other problem... and 4.1.2 works perfect with 22500k antutu
on 4.3 i get 24k antutu but i have the flickering
Ideomotor
Visitor
Really... Don't buy it. I bought mine 3 months ago and I never regreted a phone so much.
Get the Nexus 5, it's not that much expensive and it's way better.
