Hi friends,
A few days ago to update my Xperia Tx JB 4.3 (9.2.A.1.199), that after this the volume level bar is not displayed correctly. Just get a gray rectangle. There will be some solution for this bug?
Solved! Go to Solution.
That sounds strange. Could you try to boot your phone into safe mode to see if the same thing occur:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
Not in safe mode still the same problem.
How about what I suggested?
Alexdon, I did what I suggested I put the default theme and reset the phone. The volume bar appeared in its normal form. Inclusive change the default theme and install Triflat theme, the volume bar working properly followed. Thanks for the solution.
Great.Anytime!
